kyosho new ep heli !!!!
    Kyosho EP Concept SR-K Kit
    Length:760mm
    Body Width:132mm
    Main Rotor Diameter:865mm
    Total Weight:approx. 1,430g
    The EP Concept that set new limits for electric powered heli flight has enjoyed many years of strong support, from beginner fliers to experts. The EP Concept produces outdoor performance equal to that of engine powered helicopters. The famous performance of EP Concept has now evolved into the more powerful "SR-K" .
    Detailed scale form of the Schweizer 300C body delivers double the satisfaction with looks and performance. Kyosho’s long years of design experience produce a realistic scale body that is also lightweight and requires no painting to complete. This is a kit of the highest quality and designed for fast and easy assembly.
    The "S-Power Stock 14T" motor produces powerful flight and extended flight times. New design of the Swash Plate and one-piece tail rotor grip structure produces a more direct control feel. The EP Concept will be the best flying partner you could wish for, whether it is your first helicopter, or your Sunday flyer!
    Special Equipment:
    Energetic outdoor flight made possible with the high torque 540-class “S-Power Stock 14T” motor.
    Seesaw head using full-length spindle shaft with bell-hiller system promises sure and responsive flight control.
    High-rigidity frame and mass concentration from the design results in easy control characteristics.
    Able to deliver a fascinating range of performance to thrill everyone from beginners through to experienced fliers.
    New kit components are easy to assemble and maintain.
    Increased scale detail and appearance with braces and skids for that real heli feeling.
    New structure of tail drive pulley and tail rotor grips produce increased control response and feeling.
    Firmer support for the tail pitch slider bearing results in improved rudder control.
    Newly designed ruder linkage guide is not only easy to install, but reduces slippage.
    4-channel, 4-servo Helicopter Radio System
    Speed Control AMP for 540-Class Motor
    Mini Gyro System
    Minimum 8.4~9.6V-2000mAh Ni-CD or Mi-MH Battery
    Battery Charge
