This is my 1st 450 size heli I got, bought it from Heliguru. Had been learning to fly with King2, time to try something more stable. Just finished fixing up everything and done all the setup today. Have to thanks Pang for helping me on problem I face during fixing up the heli, very helpful guy. Still help me even though I sms him late night after 10pm. Have not done maiden flight yet. Here are some of the pictures of my Flasher 450 PE.
My 1st 450 Heli Flasher 450 PE
Good luck on ur maiden. Look forward to more photosMy Hangar:
(SE-maiden 15/03/06)
(XL-maiden 16/10/05)
Heli 2:RAPTOR 50 TITAN
(TITAN-maiden 16/06/2006)
Heli 4:Flasher 250
(maiden 13/09/2010)
Transmitter:
JR 9XII(XPS 2.4)
Originally posted by Niven View Posterm iszit ur tail blades put in wrong direction?
lols... then dun maiden it yet b4 u change it >.<
if nt later confirm get into an uncontrollable piro... =(
...Only comment I have is to change the tail servo to something better ! (HS-5084 perhaps) ...you want a fast servo of at least 0.09sec/60 deg at least.Seriously running out of ...Storage space !
Wowww!! nice heli! got one too. However.., Just be carefull with the screws they are too brittle... I suggest you replace all the screws with mks screws or some decent screws you can find.
And the most important of all: The tail boom mount- It has no notch inside to hold the boom, no matter how tight the 4 screws are still it will slip and move resulting to belt slip and crash.. I noticed you taped the boom before mounting..I tried that also but still the tail boom is rotating and moving slightly.
- The major solution: You can screw the boom from the inside of the mount, (place the screw at the tail boom slot and if you look at closely there's a tiny hole inside the mount which perfect for screw to fit) use only 1 flat head and short screw, make sure the head is not popping out or else it will tear the belt. If you do these your heli will be ready for some agrressive flights and light 3D.
That's about it, the next thing you need to do is bling it.
Good luck bro! Have fun!
Originally posted by wireframan View PostWowww!! nice heli! got one too. However.., Just be carefull with the screws they are too brittle... I suggest you replace all the screws with mks screws or some decent screws you can find.
Thanks for the solution, can show me some pictures of how u secure the tail boom with the screws? Can't really visualize yr solution. Btw I'm using those white tape use for sealing water pipes to tape the tail boom b4 fixing it into the heli body.Heli
1 - Flip360 quad with APM 2.6.
Plane
1 - Durafly P-51 Mustang - Nice scale details and stable in the air
Tx
Frsky Taranis X9D
