You normally hover at around 80 or 90% of motor power. Hovering at low power is not efficient.
Or rather you should keep your motor spinning at almost constant RPM.
And yes, its not gonna lift off at half stick, it will start yo get off at above 60% stick. This is almost the norm for collective pitch helis nowadays.
1. Able to hover at mid stick
2. Hover at about 60-70% stick
The reason why some ppl wants to hover at 60-70% stick is because when you change to idle-up modes, which grants you the ability to do inverted stuff, your mid stick becomes 0 pitch. This is because you want symmetrical response.
If you are hovering at mid-stick and you suddenly change to idle-up, you are going to fall.
Idle-up -
pitch -11 low,0 mid, +11 high
throttle 100% all the way or a almost flat V-curve.
Actually, i should find a website that explains all this in detail, kinda confusing explaining bit by bit.
Idle-up -
yes my setup is same as yours.
mid-stick hover for scale and normal
60-70% stick for 3D helis so the transition is smooth between modes
Chuang Yee
[COLOR="DarkOrange"][SIZE="1"]Thunder Tiger G4 Nitro & G4 E720, Goblin 500, 630 & 700, Compass 7HV, JR NEX 50 FBL Nitro, Logo 550SX, Blade 130x, Shuttle Plus 2+, Hirobo SDX thats all [/SIZE][/COLOR]
