I read from RC Heli mag that there is a setup between Tx and ESC, is there a need for this? I don't seem to have read it in the manual.
ESC setup
You are right.
I have read of setup Tx for throttle and pitch but do we need to for ESC.
I am new to this, and I am trying to understand all basic concept of setting up instead of just getting others to do for me. I believe in knowing why I need to do a certain setting so that I can improve in the long run.
Originally posted by Ghostfit View PostI believe they are refering to the process where you sync the ESC and Tx's throttle movement range so that 100% throttle on the Tx = 100% throttle on the ESC.
Pardon me if I'm wrong
No Tony, you're not.
It's known as Stick Calibration and it is usually done with TX stick started at the Full Throttle position and down to Lowest Throttle position after the acknowledgement beeps to calibrate the parameters to the ESC. (beep differs from ESC to ESC)
SKY HOBBIES SINGAPORE
Tel : +65 6293 3968
Website:
Official You Tube Channel
FACEBOOK :
Originally posted by Cklasse View PostSO this is a must do step to calibrate the ESC?
If you are running on fixed throttle mode/linear throttle curve, it is best that you calibrate the ESC to the Tx stick movement.
For my boat esc, no gov mode, so I do the calibration on my ESC and Tx.
