I've noticed that many guys have bought this heli so I decided to start this thread to share our set ups and problems.
Here's mine
Motor : Stock 3500KV
ESC : Scorpion 55A
Cyclics : HS-65HB
Tail : 3500G
Gyro : JR 770
Battery : 2200mAh 3S1P Kong Power
Main Blades : Beam fibreglass blades
Tail Blades : Dream Designs
Here are some pictures
Notice the little mark at the bottom of the inside of the canopy, it's a drop of solder. When After I was done flying the second pack in a row, I realised that the battery pack and ESC was EXTREMELY hot. On closer inspection I found that the solder on my battery connector had melted and dripped inside the canopy! Luckily I had already landed when the wire disconnected...
Anyone has experienced this before?
I also realised that this stock motor bogs very easily. Even when I do a normal punch up, the headspeed drops drastically.
Besides that, I think that this is an extremely stable yet agile heli. I cannot comment more because so far the motor is bogging too easily and I cant fly very well at all...
Here's mine
ESC : Scorpion 55A
Cyclics : HS-65HB
Tail : 3500G
Gyro : JR 770
calling johnny ( phantomGT )!!
Luckily only a small area was scratched off and the main gear slightly stripped. I simply moved the motor further in and it was meshing together fine again.
Maintenance b high if it takes only good or newer batts
