Telebee Headlock Gyro needs help
    dear all teachers,
    Anybody try Telebee gyro from ---------??? Cost is attrctive, so I bought 1. I put it on my T-Rex450 but it's not perform well .When do figure-8, just fell that rudder need to cover in all time. When invert, , don't know how to explain.
    On the gyro, that is 2 analog adjustable ports. For 450 size E-heli, how should I set to get the best performance?
    1) AVT-HeadLock port
    0% (turn anticlockwise to max)?
    50%? or
    100% (turn clockwise to max)?
    What happen if we put 0% or 100%?
    2) Gain port
    50%? or
    I'm only "half bowl of water" still in learning stage and polishing my heli set up skill.
    Which part of Singapore are you located ?
    Would be very much easier to help you if you can go to a FF.
      ya u sholud go to the funfly so that some one can explain to u more clearly. is abit hard to explain with word over here. there are alot of helpful ppl in the FF that can help u.
      Heli
      .FBL Protos
      Plane
      .Jetiger
      .Kinetic800
        Hi Ghostfit & wan81sg,
        Normally where yr guys fly??? Time??? so that I can go to the side and get more info and learn more flying skill from sifus
