How to see if spoil / ware out, need to change?
Main Gear
I have been using the 1st one since day1,so the main gear is a tough 1 to wear out, if you feel meshing lose just adjust the pinion closer, to tell if spoil,is that some of the teeths on the main gear got disfigured, or become ultra blunt,you can also see alot of plastic shavings,Originally posted by flightsimmer View PostHow to see if spoil / ware out, need to change?
all this can be seen in a main gear after a crash«Kira'sHanger™®»:
HK450MT ( awaiting elecs)
yup , basically after a gear is "stripped" as seen in zxyong's picture is when you need to change it . Or the teeth are just too worn out that you gotta change it cause if you dont , the gears would not mesh , that kinda situations ... the "black stuff" should be something like oil , or some random stuff from the surroundings , motor pinion?Originally posted by zxyong View Post
But for me , i'd change it when i think the gear is worn out
its up to you really ...
check your brass pinion, they wear out faster than the main gear------------------------------------------------------
Flasher 450 Pro/DX6i/DSM2 AR6200
Savox SH-0257/Savox SH-1357/Align GP750
Phoenixtech Gold Line 2221-8/Hobby Wing Pentium-40A
