What do you like about your 500 size? Design, mechanism, 1st impression, flying weight, flying characteristic or brand?
Which 500 size electric do you prefer?
14Trex 50014.29%2Trex 500 ESP50.00%7Atom 5000.00%0MSH Protos 50035.71%5HDX 5000.00%0JR VIBE 500E0.00%0HIROBO LEPTON EX 5000.00%0The poll is expired.
今天不努力工作,明天努力找工做。
不在乎天长地久,只在乎曾经拥有。
长痛不如短痛,短痛不如不痛。
Too much $$$ fly fly fly, Little $$$ less fly, No $$$ see people fly, Save $$$ buy and fly.
If you take care of your heli, your heli will take care of your pocket.
Be gentle with your heli so that your heli will be gentle with your pocket.
Alees Rush 750 (FBL)12s
Outrage Fusion 50 (FBL)12's
Outrage 550 (FB)6's
Outrage G5 (FBL)6's
Compass Model Warp 360 (FBL)6's
Trex 500 (FB)6'sTags: None
Protos
Advantages:
Low Weight
High Quality parts
Superb Fit
Good hardware (scews ball links etc)
Wire Management
Super fast head
Single Belt design
Disadvantage:
Fragile (depends on how u crash it also)
Stock 9mm main blade holders.. zzz..
Fragile plastic canopy
cheers!
450 PRO - Phoenixtech Scorpion 2221-8, Castle Creations Phoenix 35, Hitec HS65HB cyclic, Futaba 9650 tail, (hanger)
MA Furion 6 - Savox 5055 560KV, Castle Creations ICE 80HV, Turnigy 959MG cyclic, HK47110MG tail, Castle Creations BEC pro, BeastX
MA Fury55 - OS55HZ + Outrage EVO55 pipe, HS5625MG cyclic, Spartan + HK47110MG, Align 2 in 1, Align Governor.
Kasama - Savox 5065 550KV, Castle Creations Phoenix 85HV, HK47110MB tail, Hitec 7985MG cyclic, BeastX
Originally posted by JYHELI View PostYou got to give me something so I can vote..
But seriously Protos, if I can vote for Rave because of its unquie category.
Bro. Only 3 heli Outrage G5(Nobody own this in Singapore), Rave 450(JYHELI) and SJM 325 LE(Phantom GT) can accept 350mm blade leh.今天不努力工作,明天努力找工做。
不在乎天长地久,只在乎曾经拥有。
长痛不如短痛,短痛不如不痛。
Outrage 550 (FB)6's
Outrage G5 (FBL)6's
Trex 500 (FB)6's
cool
Originally posted by Radio man View PostBro. Only 3 heli Outrage G5(Nobody own this in Singapore), Rave 450(JYHELI) and SJM 325 LE(Phantom GT) can accept 350mm blade leh.
Is ok not to list Rave because you will have problem classify that heli as it don;t fly like 450 size.
Jonathan
Mine are the SJM360 and SJM360T1, both swing 360mm blades but also can use anything down to 325mm also lah...POWER IS NOTHING WITHOUT CONTROL!!!
Originally posted by JYHELI View PostANy problem with that. You only fly one heli at a time.
JonathanPOWER IS NOTHING WITHOUT CONTROL!!!
Not yet a Outrage G5 in SG?
1. Hum kinda weird, thought it's a pretty good bird yet not a single in SG?
2. Should I b the 1st? Nar don't wana b guinea pig
3. Besides I'm nuts with setups.
Learning Stall Turns
Mode 2 Heli Masticator
学习神龙摆尾
美国手直升机毁灭者
I prefer Alien/Revolution
Originally posted by Radio man View PostWhat do you like about your 500 size? Design, mechanism, 1st impression, flying weight, flying characteristic or brand?
a. it has a strong metallic upper frame that holds the electronics, motor & rotor head, making it a higher precision m/c.
b. The lower half's a carbon fiber batt. tray & skids. making it light & w CG around it's main rotor.
c. The tail slider tops it all, it's a rod directly link 2 the servo gear! No horns needed! Meaning there's less mechanical loss & no push & pull joints(That's how my tail boom broke on my 450SE, joints!)
2. I give it a 8.8 on scale of 10.
Radio dude if u r getting 1 of these count me in, cuz I needed ur kind support on precision tuning
学习神龙摆尾
美国手直升机毁灭者
