Is mini titan E325 better or E raptor or Trex 500? pls help me suggest haha i dun noe which 1 better for me to fly
mini titan or trex better?
And if you're really only just starting out on heli, go get a fixed pitch type like the Honeybee first. Fixed pitch helis are tougher and more durable than CP helis.------------------------------
But is more stable, but also more expensive
By the way, collective pitch works like, if you pull the throttle stick straight to the lowest, your heli will slam into the ground.
And i agree on getting SE version, i got an XL and now its got metal head and tail, just a matter of time before i change the whole frame.
Originally posted by Bee_Flower View Post
For collective, the pitch change will slam the heli into the ground.
Both got their faults and good points.
i donno how to say, lol
Originally posted by zxyong View PostWith respect to fixed pitch, if you throttle down quickly, fixed pitch will slow down until the rotor stops, then drop to the ground.
i donno how to say, lolAfter so many years, I am still a beginner
Can I confuse the TS a little?
Of course there are clone Trex which should be cheaper than the original.
You can check out hobbyc_ty, they sell a kit heli which is cheap but always no stock.
As for stability, I hear a lot of bros say that Mini-T is more stable as it's slightly heavier.
So, you choice lah. You wan stability or cheap lor..."To cease smoking is the easiest thing I ever did. I ought to know because I've done it a thousand times." - Mark Twain
Originally posted by Bee_Flower View Postwhether fixed pitch or ccpm....depends on individual....
as for Trex....better to get the SE version... but it is expensive....I prefer mini titan over Trex....get a used mini titan to learn so u don feel so heart pain when crash....
Originally posted by foxkilo View PostAnd if you're really only just starting out on heli, go get a fixed pitch type like the Honeybee first. Fixed pitch helis are tougher and more durable than CP helis.
Don't buy any first, just join any funfly group and observe from there. After that I believe you wil know which one to buy.今天不努力工作,明天努力找工做。
不在乎天长地久,只在乎曾经拥有。
长痛不如短痛,短痛不如不痛。
Alees Rush 750 (FBL)12s
Outrage Fusion 50 (FBL)12's
Outrage 550 (FB)6's
Outrage G5 (FBL)6's
Trex 500 (FB)6's
