I want to use my Optic 6 to fly Lama v3 instead of being stuck with the stock E-sky TX. Problem is, I cannot get the 4-in-1 to respond...
Optic 6 is running with HPF-MI + 72.65 Hitec TX crystal. I plugged a Hitec RX single-conversion crystal, matching freq, into the Lama's 4-in-1... but nothing works.
Anyone tried using Optic 6 or other TXs with E-sky RXs or 4-in-1 before? What's the correct configuration required?
I've read in US RC forums that Optic 6 with Spectra module can be used for Lama v3, as long as a matching Hitec single conversion RX crystal is inserted into the 4-in-1... not sure if this is true, but then, it should also work with the HPF-MI
