Main blade diameter: 680mm
Tail blade diameter: 130mm
Length: 650mm
Height: 230mm
Weight(Including Power System):: about 670g
Motor:: 400-450 brushless motor (EK5-0006)
Suggested 12-13 tooth for 400 motor,
and 10 tooth for 450 motor
Rotate ratio: 140/110:22
Power system: 25A brushless speed controlle
Gyro: ESKY professional gyro (EK2-0704)
Servo: weight:7.5g;torque:1.0kg.CM;speed:0.1S/60°
Transmitter: 6-channel or above 6channel(helicopter system
Battery: Li-poly Battery 1800mAh,11.1V,20C discharge
I have a 1300ma 3s1p 11.1V. can it be used for the heli? i just got it.. NIB... dun wanna waste it...
Length: 650mm
Height: 230mm
