Was surfing and found this.. Anyone with N9 care to share their experience?
Thanks.
What's happenning at Synergy R/C
Saturday, 20 December 2008
Team Synergy would like to wish everyone a Merry Christmas and a Happy New Year! We are working hard to bring you new and exciting products in 2009. Our most current project as most of you already know is the N5. We can't spill the beans as far as a release date, but we can tell you a little bit about the model. Here are some of the features:
* 120 degree push/pull control system w/ single axis bell crank shaft
* Main Gear Ratio - 8.5:1
* Tail Gear Ratio - 4.66:1
* Main Rotor Diameter: 1355mm (600mm main blades)
* Tail Rotor: 245mm
* Programmable Rotor Head will suit pilots from beginner to competition
* Collective Pitch Range +/-14.5 Degrees
* Pinch style CNC fan hub for easy "no dial" installation
* Heavy duty tail hub design with dual radial AND thrust bearings on each tail blade grip
* 10mm hollow main shaft / 8mm solid head axle
* 425cc (14.5 ounce) Fuel Tank
* Designed with ease of maintenance and setup in mind
* Modular servo and radio trays allow for very clean radio installation
* Same sleek canopy as the N9, just smaller
See you in 2009!
Team Synergy
Thanks.
* Tail Rotor: 245mm
See you in 2009!
Team Synergy
