when would be a good time to start setting idle ups? i'm currently in the stage of learning stall turns right now. for up till loops and rolls, should a less extreme idle up be used? like -5,0,9 instead of -9,0,9? do share your settings too
Idle Ups
Yeah.... me too is interested to know ...
I saw ppl hovering point is the same at normal mode and idle up mode ~ 3/4 point. Then literally, are not utilising the entire stick range available
Like Art mentioned, he hover at half stick in normal mode, the moment u flick to idle up, heli will kiss ground?
Mike
Mike
Nope we're not... that leaves us with the max point to throttle out before the heli kiss the ground...
Brandon, my settings is normal & idle1 mode, 50% stick hover, so switching between normal and idle 1 no change in pitch during midstick. My idle1's negative pitch is a little bit more for looping & rolls & to get out of trouble...
For idle2, hovering is point is about 3/4 stick, and I'm pretty used to that coz b4 a stunt, I'd be punching the heli up to gain alti. so during the climb, my flick to idle2 seems to be seamless.....then when finishing with idle2 stunt mode, normally I'd be descending....so when the heli is high up, descending at midstick, , i flick back to idle 1, and it will slow my descend....
Just a personal pref.... It'll be totally up to u to config your heli to suit your flying preference...[SIZE="1"]
[url]www.dxnmedia.net[/url]
[/SIZE]
