Hi guys,
Me searching for solution for a fren who owns a trex 500. He has vertical tail vibes at hovering after a crash. After consultation at a LHS - he changed main shaft and tail rotor blades. Problem persist and I took a look to help find the problem. Heli has perfect main blade tracking. tail blades track perfectly too.
Findings:
1. Heli rocked back and forth on table just by spinning main shaft by hand (main blades removed)
2. Auto rotation gear slightly warped viewed from side.
3. Main gear has free play. can be rocked at least 2mm up n down each direction. Is this normal for trex500??
4. We disengaged tail belt from tail drive gear. Hand spinning did not induce fwd back rocking.
5. Belt re assembled and test hover. Rocking motion noted while heli spooling down - main gear stop spinning oredy-
My suspicions:
1. Main/auto rotation sleeve damaged/bent?
2. Warped autorotation gear causing vert vibes? **
3. Tail shaft bent? (but track ok leh n pitch sliding mechanism is silky smooth)
** The 'vibes' are not violent and fast. Rather a chopping motion at a rate of about 1-2 chops a sec. Hope it paints a clear pic.
Any input greatly appreciated guys!!
Findings:
My suspicions:
