hi bros
decided to try a 3300mah Hyperion pack on my 450 and it worked great!! 10mins flight time on idle up. put back ~2700mah in 65mins after the flight.
weight of pack is 260g, about 100g heavier than usual 3S packs but the extra flight time is worth it.
below are some pics of the mods i did to my trex to fit the batts, had to saw off the servo mount area and refit the servos with Mini-T holders. i think the servo mod is already familiar.
other catch is only can fit in Mini-T canopy cause the batt pack is too big.
i might pick up some 335mm blades to improve disc loading.
with some cheap sources of 3S high capacity cells, it would make more sense to go with high capacity packs
