Actually i would suggest u save that bit of money for the hardened main shaft unless its cheaper than the normal main shaft.. Because no matter how 'light' u crash, im sure that u would not want a unreliable main shaft in the newly repaired heli right?
Mini titan also has its own hardened main shaft and i find no difference in the performance whatsoever.. The only difference is that when it crashes, the hardened shaft would not bend as much.. But that also depends on how u crash it..
AR Drone 2.0 Walkera Ladybird Micro Quad Jr XG8 Tx (Mode 1)
RG831B Rx
Agreed with John. Unless you're lucky enough to save your heli, or else the crash will still bend the main shaft. The hardened main shaft will bend lesser, but in the end, LPPL, still have to change main shaft. Ask me how I know...
I had a very hard time with the Beam too actually. A lot of lockouts that I couldn't resolve. I believed Nazar who has Beam as well encountered this issue as well, so be sure to take note of it.
Read the diff between PCM and PPM and most importantly on PCM lockout. Some of these glitches or lockout could be due to the carbon frame and way we route our electronics. So when you crash, it is best to determine the cause, nothing worse than recurrence equipment issue. Can pull hair out resolving it.
I have tried both and no noticable differences. If anything, u want the shaft to be weaker, not stronger, so that there is a higher chance that the main shaft absorbs any impact during a crash and not transfer it to the main frame or the mounting blocks.
I am on 2.4Ghz. Any problem with that?
Akira. Planes - Vladimir Maxa4/Vladimir Blaster3/Vladimir Elf
