What's the right gain for JR770T pair with Hyperion rudder servo(0.05s) which is fix on Mini Titan? Tail keep on wagging whenever i power up despite the gain adjustment. Don't know what's wrong with it? Need advice from heli flyers.
What's the right gain for JR770T with Hyperion rudder servo(0.05s)for Mini Titan?
今天不努力工作,明天努力找工做。
不在乎天长地久,只在乎曾经拥有。
长痛不如短痛,短痛不如不痛。
Alees Rush 750 (FBL)12s
Outrage Fusion 50 (FBL)12's
Outrage 550 (FB)6's
Outrage G5 (FBL)6's
Trex 500 (FB)6'sTags: None
Originally posted by Heli_fanatic1) Gain settings are not consistent amongst all helis
2) Are you running governer mode ?
3) IF needed , did you setup in rate mode.....今天不努力工作,明天努力找工做。
不在乎天长地久,只在乎曾经拥有。
长痛不如短痛,短痛不如不痛。
Outrage 550 (FB)6's
Outrage G5 (FBL)6's
Trex 500 (FB)6's
Hi, I am using JR G770T with 9257. It works and holds better than my Futaba401.
You must remember, the setup has to be these. I studied it for quite a while in HeliFreak and RunRyder and got it to work this well.
- End-Point-Adjustment has to be Max. Mine is +110 & -110 for MPX TX
- Dual Rates at 50%, as recommended by the forumers.
- Exponential at 40%, as recommended by the forumers.
Hope it helps. The setup 401 and JRG770T is entirely different as what I experience. I tried using the EPA to adjust without using Dual Rates and Exponential, the results is disasterous....
Originally posted by HotDogBunHi, I am using JR G770T with 9257. It works and holds better than my Futaba401.
Hope it helps. The setup 401 and JRG770T is entirely different as what I experience. I tried using the EPA to adjust without using Dual Rates and Exponential, the results is disasterous....今天不努力工作,明天努力找工做。
不在乎天长地久,只在乎曾经拥有。
长痛不如短痛,短痛不如不痛。
Outrage 550 (FB)6's
Outrage G5 (FBL)6's
Trex 500 (FB)6's
Got a hunch it should work. Just make sure if your servo is a digital, the setting on Gyro should be on High, check the manual in case I'm wrong.
All servos function more or less the same. Its the setting on the Gyro that makes the difference.
Once you've set it up nicely, you'll have no regrets
Now my Mini Titan's tail won't even wag when there is drop in headspeed while banging the collective
Funny thing is that my D/R is also 50% and Expo is 35% but I still have full travel on my rudder. Gyro sense is 61% at idle up. Don't use the set-up procedure for GY401 with this gyro is entirely different. This gyro uses D/R to control piro rate whereas GY401 uses ATV or end point. When you increase the gain the piro rate will be slower so set to the values you're comfortable with and have fun.Align TREX 600 N Pro With Skookum 720
Align TREX 500 With TT GT5 FB
Bros.
Still cannot. Whenever power up or power down the tail still wagged. Don't know what's wrong. Wondering if there's anything wrong with the Hyperion metal digital servo 0.05s or the JR770T Gyro. Another problem is that sometime the tail pitch control set cannot travel full to one of the end point as a result the tail keep on spinning regardless of input control to the right to counter it but still in vain. After that i checked it out and realised that whenever the tail spin it can't slide to the other end and whenever it is slow down it can. Still investigating what's wrong with the full metal tail? For your info plastic tail doesn't give me any problem with the combination of Futaba 240 and Airtecnic servo 0.12s until recently I've upgraded it to metal tail with the combination of Hyperion metal digital servo 0.05s and the JR770T Gyro. Spektrum TX setting: (ATV:150 left and right)(Auto, Gain:53, Expo:40, D/R:50, LMT:Full, Servo outputow}. Thought of getting a Futaba servo and try it again. Please advice.今天不努力工作,明天努力找工做。
不在乎天长地久,只在乎曾经拥有。
长痛不如短痛,短痛不如不痛。
Outrage 550 (FB)6's
Outrage G5 (FBL)6's
Trex 500 (FB)6's
Originally posted by HotDogBunWorth a try to change the servo. For Trex500 I'm using 9254. Smaller than this size I'm on 9257. But you can use 9257 on Trex500 though. Mine is alittle overkill
Have faith mate今天不努力工作,明天努力找工做。
不在乎天长地久,只在乎曾经拥有。
长痛不如短痛,短痛不如不痛。
Outrage 550 (FB)6's
Outrage G5 (FBL)6's
Trex 500 (FB)6's
Originally posted by erwinseowHi.... have you tried changing the gyro output direction? There is a switch on the Gyro that allows you to do so.今天不努力工作,明天努力找工做。
不在乎天长地久,只在乎曾经拥有。
长痛不如短痛,短痛不如不痛。
Outrage 550 (FB)6's
Outrage G5 (FBL)6's
Trex 500 (FB)6's
Radioman,
what spektrum TX are u using?
are u using that "gyro sensing" function? i suggest NOT to use that. just use a single channel and purely EPA to adjust the gyro gain. use the flip switch to change between head holding and rate mode.
i have 2 JR770s and both work perfectly.
drop by anywhere that got funfly and get some help. easier than trying to diagnose your problem over internet.
good luck!
