Lama or Forget about having one??
    Hi DH bros,
    I need your help i got the miniT kit w/o elctronics.......
    in the sim i learned
    1.hover
    2.nose in hover
    3.Forward Flight
    4.inverted hover
    5.inverted nose in hover
    6.and a not-so-perfect backward flight
    based wat i state in the above.........should i go get a lama for more practise
    or juz use the money wisely to finish up my miniT
    Thanks in Advance
    «Kira'sHanger™®»:
    HK450MT ( awaiting elecs)
    Mini T .................. =.=
    Helis
    Logo 500 3D
      Mini T.
      I have a Lama and also sim. No kick leh. But if you are busy and no time to go out flying, then get a Lama.
      Akira.
      Planes - Vladimir Maxa4/Vladimir Blaster3/Vladimir Elf
        Originally posted by kiratime
        Hi DH bros,
        1.hover
        2.nose in hover
        3.Forward Flight
        4.inverted hover
        Thanks in Advance
        Since u already practice those flights in SIM, u can try it in the MT PROVIDED u r confident.
        If not, either practise more on SIM or fly higher, coz u have higher height & chance to recover the heli should ur mind goes blank.
        U can also start with filp, to get the hang of going 180 deg, n 180 deg recovery back.
          hi thanks for your comment.........BTW do you know any LHS selling cheap(perfer to be below 150SGD) charger for miniT(3s) ??
          thanks again in advance!!
          «Kira'sHanger™®»:
            If you want , i have a Triton Jr ......
            Helis
            Logo 500 3D
              oooo got pics??
              «Kira'sHanger™®»:
                There are a lot of chargers available in LHS. For a start, get a charger with built-in-balancer.
                I'm not sure abt other brand of charger but I'm using the Imax charger. A good entry level charger for fliers.
                  Check this out.
                  http://www.jethobby.com.sg/cgi-bin/e...13&idx=1&gid=7
                  Akira.
                    Thanks again btw do you know how to remove flybar paddle from the flybar its very tight and i forgot to put glue as instructed in the manual
                    «Kira'sHanger™®»:
                      Originally posted by akirared
                      what do you think about this?? isit a good charger enough?
                      «Kira'sHanger™®»:
                        If charging lipo only is what u want, get a cellpro 4s charger.. Been using everytime at the field and its a fast and clever little charger..
                        AR Drone 2.0
                        Walkera Ladybird Micro Quad
                        Jr XG8 Tx (Mode 1)
                        RG831B Rx
                          You mean this charger.
                          http://www.revolectrix.com/cellpro.php
                          How is the charging?? What do I need to use it at home?
                          Akira.
                            Sorry, i dun quite get this question.
                            To remove flybar paddle from the flybar, just turn both of the paddles in a anti-clockwise direction
                              Yup.. This is the one.. If im not wrong, my friend uses a power supply to supply power to this charger.. The charging is all automatic.. It senses the battery capacity first then it begins by slowly charging at low amps and slowly increase until it finds the peak amp and stays there till charging almost completes.. If using the Revolectrix lipo, the charger can charge the lipo at 4A.. Which is about 2C.. My other batteries can max charge at 3A.. Approximately 30mins of charging time..
                              AR Drone 2.0
                              Jr XG8 Tx (Mode 1)
                              RG831B Rx
