Trex 700
    Hey by the way I found a kick butt canopy that totally changed the shape of the trex 700..the one that comes with it looks nice too but this is really killer.
    Whiplashing soon?
    Crash records counter
    JR Vibe 50: 01
    Trex600N Pro: 01
    Kasama Srimok 90: 01
    TT Raptor 50: 10
    TT Raptor 90 3D: 01
    MA Fury 55: 01
      I am a full time student...go sch at 10, back home by 5.30, the rest of the time sitting in front of the kit
        BTW, I fly at bukit panjang.
          Baby.. What engine will you be using for the 700?
            91SR with MP5. Got them 3months back.
            Rotor just got the 91HZ in...might be worth looking at.
              Cool.. Do let us know how it perform.. Better still keep us posted on your maiden.. so that we can go kapo a bit..
                Governor sensor
                Used the tj pro 30/50 mount and had to cut it down quite a lot. Not sure if my sensor is going to hold up under this type of mounting method. Only time will tell. Spacer was required to space the sensor out from the frame.
                Very bare main frame.
                Only complain here is that the holes in the carbon frames are not very well cleaned. The rest fit very well and al was square on first attempt. The manual assumed that nobody will run a battery switch, but I do. Only after building the whole heli then I realise you should put the switch in BEFORE building the frame.
                Tail Assembly
                I opted to use the metal boom.
                Not sure how much the tail case should clamp on the boom, but on mine, if you tighten it down too much, it bends the tail fin. Photo shown w/o tail fin mounted.
                Tail case did not require any assembly and tail grip/hub was VERY VERY well loctited.
                The tube torque gear in the main frame appears to be just held on by a pin. Not sure if it will fly out like in the raptor 90. Hopefully not.
                Engine/Fan hub
                Again, no drama here. The prop nut required a long reach socket. Everything went on just nicely as it should. Fan hub is pushed in, then clamp on with two set screws. Everything fell in VERY nicely. Zero adjustment was required, but it better be, because there doesn't appear to be any room for adjustment in this kit.
                  Servos installation/CCPM mixer arms
                  Elevator servo mount required a bit of cutting to clear the wires. The linkage rod length in the manual for the aileron and pitch mixer arm to swash is a few turns too short. I increased it so that the swash is flat when everything is centered. I am getting 0.5 degree pitch at 50% pitch curve, -14 at 0% and +13 at 85%. Will need some more adjustment when I really have time. For now I suppose it should work for maiden. Pitch mixing % on my radio is 45%, is it a bit too low?
                  The control shaft on the ccpm mixer required 2 shim. After pulling and playing around, the main shaft also reqired shimming, just the thinest one got it tight. Suprisingly, I did not have the problem of "thinnest shim being too thick" issue that a lot are having.
                  Ino-lab 760 for cyclic, BLS251 for tail and hitec 325 for throttle as I am too lazy to pull out the 9254 from the raptor.
                  Boom slotted in. The torque required a lot of oil and force to get it moving into the tail boom. I made the mistake of securing the tail mount case to the main frame before putting in the boom. Boom support and fin mounting was also pretty straight forward. It is not quite as small as some have put it to be. It is actually still pretty big compared to the raptor.
                  Muffler mounted
                  Just some tips for anyone building one now. Do the throttle servo linkages before mounting the muffler. Use the lower fuel line hole if you are using a YS, the top one is blocked by the regulator. Mount the elevator servo arm BEFORE mounting the whole assembly onto the heli. Mount the regulator switch before putting the frame halfs together.
                  All had been smooth sailing, but when I reached the canopy and tail control rod part...there are some tolerance/alignment problems. Not sure if its my fault or manufacture issue...will see if I can sort them out before posting.
                  BUT ANYWAY FOR RAPTOR LOVERS...
                    You mean the raptor canopy actually fits he 700?
                      The 50size canopy is too small to fit properly, but I suppose the 90size one should.
                      TmMugen, how far are you already in your build? Are you able to thread the tail push rod into the carbon rod? Your canopy fits w/o any issue?
                        Almost done. Setting the swashplate to level is hard work. Canopy not fitted yet so dun know if it is a good fit.
                        Will post some pics once done.
                        Whiplashing soon?
                        JR Vibe 50: 01
                        Trex600N Pro: 01
                        TT Raptor 50: 10
                        TT Raptor 90 3D: 01
                        MA Fury 55: 01
                          One tip for thread the tail push rod to the carbon rod. Use a drill to hold the metal push rod and drill it into the carbon rod. wala..!!
                          One point to take note: the tail rod (tail case) is not completely parallel with the swash if you take the guide hole in the tail case.
                          Whiplashing soon?
                          JR Vibe 50: 01
                          Trex600N Pro: 01
                          TT Raptor 50: 10
                          TT Raptor 90 3D: 01
                          MA Fury 55: 01
                            Tmr on?
                            If you on, i on.
                            Thanx!
                            SLOPE SOARING NOT A CRIME
                              Ons. Although I have nothing to fly tomr. Extreme waiting for parts
                              Sold almost everything to fund for the T700.
                              Die die must see Roger's Vibe and T700.
                              Wei Yao pickup at 8am tomr.
                              Too many models , so little time
                                wow nice canopy.....Wonder if there is one for the 600N
                                YOu FLy, You CRASH, YOU LEARN..
                                Mini Titan
                                JGF500th
                                CC45
                                Hitec 65HB x 3
                                Futaba 9257
                                Futaba GY401
                                [U]colco lama v5[COLOR=Red]][COLOR=SandyBrown]
                                Align Trex600N Pro
                                JR PCM 9X II
                                e-STATION BC6
                                kong lipo
                                Dualsky
                                ace RC
                                x TREAM
