Hi, need some advice or experience sharing because not sure if my problem is a problem.
I have 3 packs of TP eXtreme 2070 mAH 25C that can fly on my TREX SE V1 for 7+ mins (and still have capacity left to fly some more but I usually stop at 7.5 min max) but on my Mini-T, can only fly for 5 min (then the ESC goes into lipo protection mode and reduce power). My flying very simple - just hovering and sport - no 3D.
AFter flying on the Mini-T, the charger typically puts back only about 1100 mAH into the lipo!
Can anyone tell me if this is normal with the Mini-T?
I bought a scale fuse for the Mini-T but I guess if I put on the fuse, the weight will make the flight time even worst - sure less than 5 mins
My Mini-T configuration:
- Stock body but with full metal head and tail
- Scorpion Motor HK-2221-8 motor with 12T
- Jeti Spin 44 ESC (set to 49% on governor mode - about 2500 rpm HS)
