Problem In Futaba 9254 Servo
    After Some Time My Servo Were Just Kill Off And Nearly Crash Last Flight I Have Change 2 To 3 Servo Alr But Still Got The Same Problem
    Anyone Got This Problem???
    Pls Advice
    what voltage are u powering the servo?
    Heli:
    Plane:
    . Ok Model Medallion
    . E*Star Storch
    . ElectriFly S.E.5a
    . Mpx EzGlider (Slope)
    Tx: JR 9XII
    Photo toy
    . Canon 7D & 500D
    . Canon 430EX & 580EX2
    . Canon 24-70 f2.8L
    . Canon 85mm f1.8
    . Tamron 10-22 ultrawide
      Pls Advice
      Me having the same problem only used for a month the servo die off during flight nearly crash.After that sometime want to work sometime don want to work.Throw it away and get a JR 8900G speed at 0.6 very good around the same price as the 9254.
      Heli
      Align Trex 600N (Nitro ) Full Bling Gyro GY611. Governor
      TJ Rev Max
      Mini Titan SE
      DJI Phantom Quad
      Glider EP
      TT Soaring Star (2M) Glider
      Reichard Baracuda (3M) Glider
      Mulitplex Easy Glider 4
      Car
      Kyosho 1/10 pitwork nitro car
      Baja 5B SS 26cc gas engine with tune pipe
      Nitro Plane
      Sportman Aviation 50
      Gas Plane Hokusei 300L 30cc Gas Plane
      Goldwing Edge 540 50cc Gas Plane
      Blackhorse Splitfire 120 size with DLE 20cc gas engine.
      Sebart sukoi 30cc gas plane
      Hokusai 30cc gas plane
      Kyosho 40 size Splitfire Os 56size 4 stroke plane.
      Hyperion Telios 90 Electric plane.
      JR9XII 72.XXX MHZ
      JR XG 14 DMSS
      Futaba 14 MZ sigpic
        I'm using 9254 servo on both my helis for nearly one year liao, no problems at all. I them.
          I used them for 4 months now on my 90, so far so good. Powering with good old nicad 4 cells only.
            Got one on my Swift 16 for almost a year leow ! ...no problems.
            I'm powering it from the ESC's built in BEC (measured it at 5.2V - No load)
              im using 9254 for a year liao
              its still good for its job
              im using good 4.8v nimh batt for the supply
                I have got one almost 3yrs and still working, ard 40+gallons of usage, almost 3/4 of that on throttle though. Its notchy and twitch a bit on the bench occasionally, but otherwise, works fine in the air.
                  make sure your gyro gain channel is plugged into the right channel. In JR, it's NOT the gear channel. I've encountered cases where the gain plug was in the gear channel and consequently it means the gain was 100%. Needless to say the 9254 kept failing.
                  Test that your remote gain is working properly by setting it to below 50%. The red light should extinguish, indicating non-headholding mode.
                  F5D Stratair Demon
                  F5D Jibe
                  Jiri Bachinski Escape Pylon
                  Voodoo S400
                  Kyosho Phantom 70 Reno racer
                  La Racer 56
                    Thank!!
                    Thank For All Yr Reply I Using 4.8v
                    Is The Jr Servo Better ??
                    Cos I Reali Scare That Flying Half Way Then Suddenly Cut Off Then On The Ground Work Fine No Problem At All
                      There are 2 ways to configure remote gyro gain on JR radio
                      1) Channel 7 (Aux 2) - have three settings to assign to up to 6 flight modes
                      2) Channel 5 (Gear) - the setting is set by changing the ATV, this is useful if your RX is 5 or 6 channels
                      I’ve tried both and they work, method 1 on my Mini-Titan and method 2 on my HoneyBee CP2.
                      Preference will goes to the first if have 7 or more channels on the RX.
                      Oh... I’m using the 9254 on my Mini-Titan with 5V, about five months now and loving it.
                      Share the joy of flying . . .
                        Hah ? ...won't it be tail heavy meh ?
                          Here a few things to check
                          - no 6V, it kills S9254
                          - make sure no binding
                          - smooth travel between full left and right
                          - set remote gain to suit flying style
                          Hope it helps.
                            move it all the way near to the tail boom grip ... looks balance ...
                              i bet. High Gain.
                              [B]Kenny[/B]
