I'm only just finding the time to unwrap and put my Belt CP together after nearly 9 months in the box. Its a CCPM 120 Swash, E Sky Gyro EK2-0704, ESC EK1-0350, Rx Hitec Mini6S, Servos are EK2-0500, Tx Optic 6 (Mode 1).
I've assembled and wired it.
Just managed to find out why the throttle was kicking in and starting the motor automatically when I pulled the elevator down twice ... believe that it was because the default Mode for the Model Setup that I chose - Model 8, is Mode 2. Strange though.
The problem I have now... is that it appears that I can only start the motor now by using the Engine-Cut switch, and I can only stop the motor totally by pressing the same button. But the cut off only lasts for 2 seconds before the motor comes to life again. Is this normal? How can I stop it totally? I have set T.Cut at -25%.
If anyone has some suggestions for Throttle and Pitch Curves for the Belt CP, can you please share them? I am currently setting the following :
Normal - 1 2 3 4 5
TCurve 0 26 45 72 100%
PCurve 0 5 6 8 10
Thanks in advance
Normal - 1 2 3 4 5
PCurve 0 5 6 8 10
Thanks in advance
