I have a Lama3. I like this heli but I have difficulty with the stock Transmitter trimmer....it always run out and have to re-trim again for every flight. Wondering a better "digital trim" transmitter will help? Anyone has such experience please advise. Thanks.
Lama stock Tx good enough?
If what you meant by the trimming is off is that you accidentally bump the manual trims on your tx, then yes, a digital trim is avoid this problem. Most higher end tx with lcd screens should have this option. An easier solution is to store your tx properly and dun let any children at home, if any, to mess around with it.
If you are talking about the trims maxing out on the tx, then the solution would be to manually adjust the servo arms to get to a better position.
I just need to trim every now and then even I never accidentally bump onto the manual trims on the Tx.
Yes, previously I also face the trims maxing problem but I have somehow solved the problem.
Anyway, beside the trim... please advise if a good Tx could make our flying of the Lama easlier as compare to using stock Tx? Anyone tried please comments. Thanks.
Originally posted by yeow_hweeIf what you meant by the trimming is off is that you accidentally bump the manual trims on your tx, then yes, a digital trim is avoid this problem. Most higher end tx with lcd screens should have this option. An easier solution is to store your tx properly and dun let any children at home, if any, to mess around with it.
bro there is notting to do with the TX..our lama 4in1 is a very sensitive esc. check out this web and hopfully it helps. as it do help me to understand my lama and make it fly better.. enjoy
sorry dono how to link..just cut and paste...
Mini Titan
JGF500th
CC45
Hitec 65HB x 3
Futaba 9257
Futaba GY401
Align Trex600N Pro
JR PCM 9X II
e-STATION BC6
kong lipo
Dualsky
ace RC
x TREAM
Thanks boo_saa, it is really a useful link. I will read all and try out again.
So, I think I will on hold for "new" Tx purchased first....using the stock Tx should be good enough for Lama...I think...
Originally posted by boo_saabro there is notting to do with the TX..our lama 4in1 is a very sensitive esc. check out this web and hopfully it helps. as it do help me to understand my lama and make it fly better.. enjoy
