I am having problem setting up my cc45 esc. The instruction state that i have to set the thro to mid stick or higer ,then bring the stick to lowest to arm the motor. I tried but cant arm the motor unless i trim the thro to -32 then it will arm. But then the worse part is thatI can cut the thro after i spool up. Need some pointers. Thanks
Help on setting up CC Esc
first, you have to follow the instruction to set the ATV for your throttle curve. then you wil be able to initialize
Originally posted by boo_saaI am having problem setting up my cc45 esc. The instruction state that i have to set the thro to mid stick or higer ,then bring the stick to lowest to arm the motor. I tried but cant arm the motor unless i trim the thro to -32 then it will arm. But then the worse part is thatI can cut the thro after i spool up. Need some pointers. Thanks
Originally posted by mavefirst, you have to follow the instruction to set the ATV for your throttle curve. then you wil be able to initializeYOu FLy, You CRASH, YOU LEARN..
Mini Titan
JGF500th
CC45
Hitec 65HB x 3
Futaba 9257
Futaba GY401
Align Trex600N Pro
JR PCM 9X II
e-STATION BC6
kong lipo
Dualsky
ace RC
x TREAM
ESC setting
Originally posted by boo_saacan explain more?
jes contact esc to motor, esc contact to RX, after all correct .follows the instruction step by step.do it. if not understand u can come over me.
pm u my contact.
