the blades flew apart causing it to shake towards one blade , causing the thing to up
fiberglass blade hs
Nazar78, i believe that it is always very dangerous to run 3k+ rpm on woodies, no matter what brand woodies..
If you want to run at 3k+ rpm, i seriously suggest getting a CF or FG blades..
Even if u glue the grips to the wood, at 3k rpm, its still very very scary.. U will not know when the blades are going to fly out! Worse if u are hovering in front of u!
Just to be safe, lower your headspeed or get CF blades..AR Drone 2.0
Walkera Ladybird Micro Quad
Jr XG8 Tx (Mode 1)
RG831B Rx
