head nobbing
    head nobbing
    my trex se v1 keep nobbing during flight........
    i have checked the tension of the belt.....and its fine...
    could it be the tail shaft bended???
    Up ur headspeed!!!
    Fly at least 2000rpm n above.
      tail blade not balanced?
      JR 2.4GHz 10X
      JR DS8717
      Solid G
      KY-3000 30% nitro
        more likely headspeed too low
        For sale
          yeah up your HS to at least 2400 rpm, you will find your heli to be more stable.
          Align TREX 600 N Pro With Skookum 720
          Align TREX 500 With TT GT5 FB
            i dun think so........
            i never balance the tail blade.....
            its too small liao...
              im using the stock se motor and 13T
              if i wanna increase the head speed...then i would need to chage to 15T??
                r u using gov or t.curve?
                13t on the stock motor shld be enuff.. bring ur throttle up
                for tcurve, try running 0,25, 70, 80, 90. be careful when throttling up
                for gov..u need a tach
                For sale
                  It could be your feathering shaft is slightly bend or your O-ring is worn out.
                    this is true, the faster your rpm, the smoother your blades, evenif you have a simple wobble that will fix it.
                    When a habit begins to cost money, it's called a hobby.
                      Till now TS have not feedback if increased headspeed helps.
                        i will check it out tonight...
