Heli Cg adjustment
    Heli Cg adjustment
    how to adjust cg of a heli WITHOUT
    1.moving the batteries (cant shift anymore)
    2. changing to other battery type (prefer my current batt)
    3. shifting tail servo
    adding weights to ur canopy
      is your heli nose or tail heavy?
      In Hangar
      Mini Titan with stock motor and ESC
      GY401
      HS65 for cyclics
      Futaba 9257 for tail
      Dualsky Xpower 2100mah
      Gforced DX7 on 2.4GHz
      Good to go!!! Go go go!
      In Garage
      Tokyo Marui Tiger I RC Tank
        tail....
          sorry my heli is nose heavy
            Maybe u could cut short your rudder control link and shift your tail servo nearer to the rudder..
            AR Drone 2.0
            Walkera Ladybird Micro Quad
            Jr XG8 Tx (Mode 1)
            RG831B Rx
              actually i dont wan to shift the tail servo becaause of the wire.
              anyway whats the best method to measure cg?
              some people say hold the blade perpendicular to the body. see which side drop.
              some people say just lift up the flybar and see which side of the skid touch the ground first?
              which is the most accurate method?
              thanks
                I always stick to the flybar theory.. =D
                So far its the best way for me...
                AR Drone 2.0
                Jr XG8 Tx (Mode 1)
                RG831B Rx
                  im using the blade theory
                  using this mehod could also allow you to feel the tensions between the main blade and the holder...
                  in fact, both theory is good......
                  if you dun wanna move anything, the only way is to add weight.....this is the cheapest way....but it add more weight to your heli lor....which lead to move power consumptions....
                    i use both, blade method to check for tension, flybar to get the cog becos if i use blade method for cog, the owb or belt could hinder the rocking. also i use flybar method so i can see the main shaft 90deg to the ground. but wat eva both method works. and i personnaly add thick washer to the tail as weight...
                    Current Blink²:
                    History Blink²:
                    Belt-CP
                    Walkera-#60
                    Nate Waddoups
                      Go Daiso, ...look for 12mm Alu tube (or 14mm for MiniTitan) in your favourite color, cut to length and replace your stock tail boom.
                      This will add about 12 grams to the tail side not to mention you'll have a much stronger tail boom !
                        daiso? where is that ?
                        Helis
                        Logo 500 3D
                          I think there's a few. ...I usually go to the one at IMM
                            changing the tail boom is very diffcult......
                            remember no shifting the tail servo..........
                              Vivo City has one branch too.
