The belt used for TRex are rated as MXL for industrial standard. Different rating has different teeth angle and the size of the angle. U have MXL, XL and etc.
In MXL, the distance between 2 teeth is around 2mm. The normal marking for MXL is like MXL472 which mean 472 number of teeth. Since u know the distance between 2 teeth is 2mm, thus the circumference for MXL472 is (472-1) * 2mm = 942mm.
To get the length for MXL472, then 942 / 2 = 47.1cm
Thus if u want to use TRex kind of belt, from the length u want, u should able to derive the MXLabcd number. Then using that number, go and ask those belt shop to see whether they have or not.
