Mini-Titan Damper
    Mini-Titan Damper
    Hey Guys,
    Notice the damper-sit of the metal T-hub of the mini-t is slightly bigger den the plastic hub. The damper doesnt seem to sit well in it. There is a slight freeplay causing the feathering spindle to rock(espcially when idel up). Its already my 2nd pair of replacement damper. Any soluition to this or is here any after market damper that have a better fitting?
    Rgds
    Tak
    FASSTGot Quard?
    Originally posted by Raven
    Hey Guys,
    Rgds
    Tak
    I'm using metal T-hub too and my dampers are still good as new the last time I took my blades grips apart for servicing. IMO the Mini T dampers are one of the most lasting dampers so far.
    [SIZE=1][B]Back to hovering!!![/B][/SIZE]
      Is there any free play on your dampers. Like what raven describe.
        Hi Art,
        Agree with you. The dampers are strong, what I mean was the ID of the T-hub seems abit bigger den the OD of the damper itself. Think I gonna try wrap a thin layer of scotch tape ard the damper and try. Every time it come loose my heli tends to Char Kuey Tiao during hover...
        FASSTGot Quard?
          mine too... and they are quite new.. can la kopi but flying seems pretty ok to me
          For sale
            Ya.. mine also flies well although there are lot's of free play.. At least it does not go like Char Kuay Tiao
            But what I'm trying to find out here if there are some inconsistency. Firstly.. The plastic hub has no free play, and it's tight.. Need to apply some silicon grease to push it in On the metal one.. I can just drop it in and off
              when i bought them the vendor told me it is a new design and it is a gd thing...!
              both of our helis seem tracked at idle up even when doing "handstand"... so i guess it's ok la.................... i hope
              For sale
                Hi Art,
                I remember mine does not dropped off by itself when inserted into the T-hub, hmmm...will double check it thou.
                  mine was the same condition as yourself raven....even with new damper its still slightly smaller. I wrapped it with a thin layer of tape.
                    Vincent,
                    Yup, dats what I intend to do. We are both using the Red T-hubs. Wonder if those silver ones is the same or is it batch issues.
                    Art2,
                    Do feedback on yours ok. Btw is yours Silver or Red T-hub?
                    Rgds
                    Tak
                    FASSTGot Quard?
                      Hey Guys,
                      Rgds
                      Tak
                      This problem.. What do you mean? Got photo to show?
                      "Keep Fly'in Till They're Dry."
                      Mini Titan E325 SE Version
                      Full CNC Metal Rotor and Tail
                      Futaba GY401/Futaba 9257
                      Hitec Optic 6 Electron/HS65HB
                      Maiden on 26 Aug 2007
                        Sorry to bump up such an old thread as i don't think starting another thread would be of use.. Since this thread still does not have the answer to solving this problem, i shall borrow this thread and ask questions..
                        My Red Hub also have the same problem.. I can drop the red damper in and it can fall out easily.. Does sticking a layer of tape solve it? Or is there any other dampers in the market that can solve the free play?
                        AR Drone 2.0
                        Walkera Ladybird Micro Quad
                        Jr XG8 Tx (Mode 1)
                        RG831B Rx
                          My silver one looks ok. not as tight as the plastic one, but not as loss as what you guys diss.
                          Mini Titan
                          JGF500th
                          CC45
                          Hitec 65HB x 3
                          Futaba 9257
                          Futaba GY401
                          Align Trex600N Pro
                          JR PCM 9X II
                          e-STATION BC6
                          kong lipo
                          Dualsky
                          ace RC
                          x TREAM
                            Ic.. But i wonder does the free play cause any problems while doing some flips and rolls? So far its been ok for me.. Im jus worried..
                            AR Drone 2.0
                            Jr XG8 Tx (Mode 1)
                            RG831B Rx
                              Silver ones also has freeplay when damper in. I switched back to plastic hubs, better. If crashed I don't have to worry screw stuck in hub after breaking off Dampers have no freeplay when in plastic hub, in fact it's kinda tight once shaft goes in. But have freeplay may be a good thing ..... you never know. It's supposed to dampen, right?
