Hi, finally put a few packs thru the Mini-T and want to share some findings and ask a couple of questions (My Mini-T is totally stock for now with headspeed around of 2500 using TP Xtreme 2070 25C with 7 mins flight limit):
1) ESC
Couldn't get the governor (Programming Setting of 5-2; with Throttle at 75% for 2500 rpm) to work well - have premature shut-down (after 1 to 2 minutes flight with "Std Lipo" protection Setting) and although can be restarted. Very frustrating.
Went back to T-P curves, no more premature shut-down and can go all the way to 8.5 minutes. Flying is ok but I prefer Governor mode. Anyone have good experience with Governor mode on Stock ESC? Can share what you do to get it to work well?
2) Blades
Tried with both Stock Main Blades and also Align 315 (take from my TREX
). No problem with blade tracking since I use the TT spacer. Seem the Stock blade like "slightly more stable" although the difference with Align blade doesn't seem much.
3) Motor Upgrade:
I saw in R***r that their demo Mini-T uses the Align TREX 430L (3350 KV matches the Stock Mini-T motor). Its an inrunner. I am using the 430L on my TREX SE - works great and is not hot after 7 min of flight. Anyone uses the Align 430L for their Mini-T?
1) ESC
2) Blades
). No problem with blade tracking since I use the TT spacer. Seem the Stock blade like "slightly more stable" although the difference with Align blade doesn't seem much.3) Motor Upgrade:
Its good to know, no wonder its not too warm after 7 min of flight in my TREX.
