Hi, just bought the MT and wanted to learn from the experienced owners out there. Hope can get opinions about the followings:
1) Main Blade Grip
Refer to Awesome's posting (http://www.daddyhobby.com/forum/show...postcount=257), anyone knows the reason why the TT blade Grip design is such that the ball link is slanted originally? Awesome's mod (shortening blade ball holder arm to have the link vertical) make sense but I was just thinking that maybe TT have a reason to make the blade ball holder arm so long even though the link is slanted.
2) HS65 mod
Intent to use HS65 and knows that the servo mount need to be widen and wanted to widen them before assembly, especially the mount molded into the frame (elevator mount). Is it just widen centrally ie. remove 1 mm on each side or is it better to remove material from just one side - I wanted to get the control link as centre as possible.
Also, anyone can advise if using HS65, what is the best distance to use on the horn ie. distance from centre of ball link to centre of horn-fixing screw.
3) Metal Head
The Metal Grip/Hub/Washout looking interesting. Any opinion if they are worth upgrading to? I plan on using the Mini-T to learn inverted hover.
Thanks in advance.
1) Main Blade Grip
2) HS65 mod
3) Metal Head
Thanks in advance.
