Just like to share some experience and photos here:
(1) If you use loctite, remember to use VERY sparingly! Esp for parts near ball bearings - Some got onto my main rotor and caused a nasty problem there. If in doubt, it would be better NOT to loctite at all.
BTW, don't loctite to non metal parts and tapping screws. And NEVER use CA.. ever!
(2) Aluminum parts are soft! Learnt an expensive lessons from Metal Flybar Control Arm - I had tighten the grub screws too much and caused some damage to the screw threads. Now it's holding with some CA (okay this was done because no choice..They cost over $20 bucks!! ). Arrgh!
(3) Take your time!I'm glad I followed what I preach. But it's testing my.. Oh well. "Have a little.. Patience"
That's about it. This Mini Titan looks good overall
Guess probably wouldn't be able to fly it as soon as I have originally planned for. Update when I make some progress..wish me luck.
Main Rotor Metal Upgrade:
Tail Metal Upgrade:
Futaba S9257 Tail Servo:
Unable to mount as the ball linkage screw is too small!!
Does anyone using S9254 and managed to solve this problem? Cuz it's the same.. HELP!
BTW, don't loctite to non metal parts and tapping screws. And NEVER use CA.. ever!(2) Aluminum parts are soft! Learnt an expensive lessons from Metal Flybar Control Arm - I had tighten the grub screws too much and caused some damage to the screw threads. Now it's holding with some CA (okay this was done because no choice..They cost over $20 bucks!! ). Arrgh!
Guess probably wouldn't be able to fly it as soon as I have originally planned for. Update when I make some progress..wish me luck. Main Rotor Metal Upgrade:
Tail Metal Upgrade:
slow and steady!
) resort ...as mentioned by Johndyl !
