Where to buy gyro tape?
    Hi guys, anyone know where to get gyro tape at a non-cutthroat price?
    i saw rotor's online shop selling a piece of 2cm by 2cm tape for...$5!!!
    Erm.. wat's a gyro tape? Do you mean the double sided tape used to tape the gyro to the heli?
    [SIZE=1][B]Back to hovering!!![/B][/SIZE]
      mockingbird has them..
      u also can consider "red" all weather mounting tape from Scotch of 3M
      For sale
        for which gyro ... the 5 dollar one i think is for the 611 with the metal plate
        Helis
        Logo 500 3D
          the D.I.Y shop in most neighbourhood shopping...forgot what name, plastic bag is light brown one.
          3m foam double sided tape. 2 types. One is black rubbery with red backing, another is white foam with white/green peel-off. I prefer the later for gyro because its a lot softer. The grey/red all weather is better for other electronic mounting because it can be removed off as a whole piece cleanly.
            thx guys! will check out the suggestions.
              the gyro tape is to reduce vibrations sent to the gyro. These vibes can be caused by the motor spinning at very high speeds. These vibes also causes the gyro to go crazy.
              In Hangar
              Mini Titan with stock motor and ESC
              GY401
              HS65 for cyclics
              Futaba 9257 for tail
              Dualsky Xpower 2100mah
              Gforced DX7 on 2.4GHz
              Good to go!!! Go go go!
              In Garage
              Tokyo Marui Tiger I RC Tank
                Ah.. I see, I see...Thanks
                  the tape are too ex lah....... i normally use the red 3M clear double side.. which is in rubber and cost 7 per roll... very good..
                    yah... i'd say for one piece of square tape cost $5 is like can DIY your own good one also. But i've tried with the 3M black mounting tape. lol does not work... lolx. tail goes crazy... lols
                    In Hangar
                    GY401
                    HS65 for cyclics
                    In Garage
                      dun use the black one
                      use the clear one with red protection
                        yup me use the red one too =D so far so good
                        Walkera #4
                        King2
                          those tape given the box(GY240) keep on coming out,cant stick well.
                          Mini Titan
                          JGF500th
                          CC45
                          Hitec 65HB x 3
                          Futaba 9257
                          Futaba GY401
                          Align Trex600N Pro
                          JR PCM 9X II
                          e-STATION BC6
                          kong lipo
                          Dualsky
                          ace RC
                          x TREAM
                            did u clean both surfaces(underside of gyro + mounting surface on heli) with alcohol b4 mounting?
                            what i also do is a put a tiny drop of CA on the surface to be mounted on the heli frame
                            For sale
                              CA...ok will try .thanks
                              Mini Titan
                              JGF500th
                              CC45
                              Hitec 65HB x 3
                              Futaba 9257
                              Futaba GY401
                              Align Trex600N Pro
                              JR PCM 9X II
                              e-STATION BC6
                              kong lipo
                              Dualsky
                              ace RC
                              x TREAM
