strange thing happened to my esc and motor
    im using hobbywing pentium 30a esc and 450th motor
    when i start to take off...
    throttle stick at 0-strange sound from the motor
    throttle stick at 1/4-strange sound from the motor
    throttle stick at 1/2-strange sound from the motor
    throttle stick at 3/4-strange sound from the motor
    throttle stick at full-the motor turn at full speed
    when the blades still spinning,i can use the trottle freely
    but when the blades stop or low rpm
    the same thing happened...
    Happened to my stock Mini T ESC. My symptom is not strange sound, but the motor jerks left/right and cannot spool up. Happens when ESC is hot.
    After that one day, the ESC completely cannot work.
    On Duty
    DJI Phantom 2 with GoPro
    Dynam Hawker Tempest
    Alfa F4U Corsair
      did u do any settings on the esc?
      For sale
        not too sure
        but if i have acc done it
        how to reset??
          Sounds like esc settings not done properly or compatibility issue
            It should come with intructions on how to set up the ESC settings you required
            Originally posted by zattan22
            not too sure
            how to reset??
              yup
              but i have lost it
              and
              i have downloaded the instruction manual from the internet
              but it never mention leh....
                sounds abit like timing issue...
                btw have u calibrated ur throttle endpts??
                For sale
                  i dun know about the settings
                  maybe i accidently set somethings to it
                  but the factory default should not have such problems
                  i just downoad the instruction manual
                  later will see into the settings lor
                  hopefully, i could rest the esc....
                    try and let us know... btw on what heli huh?
                    if possible set the motor timing to med or high for the 450th
                    For sale
                      i had the same problem. sometimes got sometimes don't have. once the motor manages to start up, no more problem. but i dumped that esc and bought another
                        Yup,
                        Throttle up, the motor jerk Left & Right,
                        Manage to find one of the connector with dry joint. If you notice, when 2 of the 3 BL motor wire are connected only, you will have this effect.
                        Check the connector for dry joint, it will give you high resistance after sometime when the temperature of the contact gets hot.
                        AIR
                        HB K2 - Service
                        CopterX 450 - Hanger
                        IFO - Service
                        Walkera H05 mini plane
                        JR X3810
                        LAND
                        Kyosho Javelin - Garage
                        Tamiya TT01 Subaru WRX - In Service
                        Tamiya M03 Hello Kitty Swift - For wife
                        Cen Mini Madness - For son
                        Team Losi Speed T - In Service
                        Tamiya TamTech Frog
                        Sanwa MXA
                        Sanwa MX3S
                        Losi 2.4GHz
                        Crash Lander
                        Can crash land anytime anywhere
                          the problem is the motor and esc is new... not hot
                          huh.... could it be that the trottle is opp liao leh??
                            i dont quite understand whats going on but have u tried to bring down to some ff to get some help?
                            Helis
                            Logo 500 3D
                              you might have to set your esc timing to high. the manual recommends so. some other motor might need low or medium. it really is quite a bit of trial and error. also check your motor connections.
