hi Art2, i doubt you can fit into the main frame but have seen someone cable-tied it below the base plate though. Use the rx foam to dampen the vibrations and for protection.
If bought as a package with a 10 channel RX, then it would have been a waste if it's not used, but again, I guess unless if you're planning on flying scale models, or big nitro heli, then again, still won't take up 10 channels.. unless use on special application. Again, what else can be fitted on a 400 size Trex??
Acrobatic planes require at most 4 channels, and scale models, as well as some smaller ones may need 5 where the 5th is usually used for the landing gear, and maybe a 6th for bombs, and a 7th one for a cam?? or gun?? and I guess you'll have to be innovative on the 8th, 9th, 10th???
