Hi all, anyone with experience programming this ESC? Need to ask a few questions. Thanks. You can add me to msn so its easier to ask? Thanks. Howard.T.Francis@gmail.com
Programming the Aplus ESC.
Originally posted by johndylerhmm unplug the motor cannot hear the beep liao.. how to program??
just loosen the pinion, or program it outside the heli. btw the motor shouldnt spin up if u follow instructions correctly
i read from somewhere that each time you change a motor you should re-do the esc setting..that means motor needs to be connected..not sure how true..
but the beeping sound is from the motor..it needs to be connected so that you know what you are doing.
unless using a usb link to do the programming.
better to remove the pinion from the motor shaft...
Originally posted by hello_hellohellofor me i remove the pillion to be safe. when unplug motor you cannot hear a thing lol........In Hangar
Mini Titan with stock motor and ESC
GY401
HS65 for cyclics
Futaba 9257 for tail
Dualsky Xpower 2100mah
Gforced DX7 on 2.4GHz
Good to go!!! Go go go!
In Garage
Tokyo Marui Tiger I RC Tank
Originally posted by SobakawaLOL i was so scared that when i plug in my batts to my ESC that i always left throttle hold on on my Tx. then i thought maybe that was what was causing my problems of not being able to program the ESC. Then i decided to remove the pinion. And behold! got into the programming mode! Sheesh... me noob first time programming a ESC. Thanks all for your patience...
Originally posted by lampardhaha... so hows the programming? done smoothly?In Hangar
GY401
HS65 for cyclics
In Garage
