King2 CG problem. Tail heavy
    Hi all. After shifting as much electronics to the front, shifting the batt to the front, the tail is still heavy. So i have to trim the elevator 20% so that my heli can hover. At this point the swash will be tilting forward. Whenever i try to aileron(bank) left/right my hei will move forwards, i believe its due to the swash being tilted forwards. Is my judgement correct? So now... the only way to solve my tail heavy problem is to add weights liaos. So where can i get weights to add to my heli? Or is there any other better solutions out there? Thanks.
    In Hangar
    Mini Titan with stock motor and ESC
    GY401
    HS65 for cyclics
    Futaba 9257 for tail
    Dualsky Xpower 2100mah
    Gforced DX7 on 2.4GHz
    Good to go!!! Go go go!
    In Garage
    Tokyo Marui Tiger I RC Tank
    ok i found some weights at rotor. http://shop.rotor.com.sg/show-detail.asp?prodid={A0ACE056-AF40-4516-A40B-D2A6BE435D26}
    is this the best solution? Anyone? I'm up for suggestions.
    In Hangar
    GY401
    HS65 for cyclics
    In Garage
      dun put weights lah.
      I'm back!!!!
        get bigger batt.
          Originally posted by motown
          get bigger batt.
          ah...? I just got 2 1350mah lipos liaos... get heavier batts?
          In Hangar
          GY401
          HS65 for cyclics
          In Garage
            Anyone got 2100mah batt with deans for me to test out...?
            In Hangar
            GY401
            HS65 for cyclics
            In Garage
              I have fix up 3 King V1&2... I dont see there a problem with the CG... It should be well balance using stock item. Did you change anything?
              sigpicGround is closer than it appear...
                yes, changed according to my signature.
                In Hangar
                GY401
                HS65 for cyclics
                In Garage
                  ya bigger batts is the better solution. i believe flameangel tested with TP prolites and DN 2150.. both balanced out the cg nicely
                  For sale
                    anyone got a 2100mah lipo for me to test out?
                    In Hangar
                    GY401
                    HS65 for cyclics
                    In Garage
                      Come down FF for expert bros to see lor...
                      Need Australian/Italian Wines ? PM Me...
                        Trust me and get yourself a 2100mah Battery and CG will take care of itself. I can say this to you becos i myself is using that. You also get longer Battery life of 12-15 minutes on a 3800kv brushless motor.
                        In politics, there are no permanent friends or enemies only permanent interest - Lord Palmerston
                          hmm.. maybe i will try out an experiment. Anybody knows how heavy are our 50cents and $1 coin? Maybe intened to put coins in the cabin until the CG balances out then see if the weight of the coins are the extra weight of a new 2100mah batt.
                          In Hangar
                          GY401
                          HS65 for cyclics
                          In Garage
                            btw, which 2100 batts are you using?
                            In Hangar
                            GY401
                            HS65 for cyclics
                            In Garage
                              For sale
