Ok I dont know if everyone is having these problems but here are some issues that I have with the t Rex
1. ball links are very lose ..easy fixed the important ones simply plastic bag them ond put the links back on
2 .when flying the rex and you give ailerion movement I always got some elevator mixing problems ..ie going side to side the heli would crab back towards me as well or forward. this I think is an issue of loose linkages...I fixed most of the problem by converting all the linkages to ball links. The problems still was present but not as much ..so the rest i got rid of with some mixing on the TX. I have put some ailerion elevator mixing in +/- 10 on both ..and it looks to have done the trick. Now I can move from side to side quickly without any forward /back movement.
3. This problem I still am sourceing. I get a bad BOBBING happening with the heli in backward flight or even with a bit of wind on the side. i suspect that it could be the battery hangging so low underneath that it can be causing a pendulum effect and that could be the cause of it. has any one else had this issue. It couls also be the massive weightof the battery too causing this too compared with the rest of the weightof the heli.
thoughts opinions?
cheers doug
thoughts opinions?
cheers doug
Now after I blown $60 on them but I will used them some where.
