Fellow users of the above gyro (if anyone), seeking your advises.
I have a TREX with GY401, but I still fly at void decks with my 'separated' FP.
I thought for $80, it is a good replacement for the non-HH PG-03 on my FP.
I want to upgrad it to CP2, if I got the PT Gyro with HH working.
I have followed all the usual setup recommendations - ie. side mounting, wait for blue light to come up, ensuring the tail rotor spin and rudder sense are correct and the gain control on channel5 (Gear) by adjusting the travel - -70 to 100 % for rate mode/+70 to 100% for HH.
I still can only get the Rate mode to work - the tail motor can spin during movement. But when switch to HH mode (with CH5 set to high travel 70%-100%), the motor will not spin, even when I move the tail or the rudder stick.
Can anyone confirm that if HH is a standard capability on the PT, or should I return to the LHS
CH.
CH.
For seperate PG03 is the way to go...
