Getting mini Titan.. advise needed
    Originally posted by detach8
    ?? 3krpm and tail hold? how "hold" is your "hold"? like as if it hit a wall after u release rudder? maybe a r50 can do that, not sure about a mini ep!
    dont understand the hitting the wall part.
    but its possible to hold at 3k rpm.
    I am a little more demanding then glenn. i want it to hold even if i punch up and down in succession.
      it should for a gd setup
      For sale
        more like as long as the tail holds straight when I punch full from 3000rpm
        JR PCM 9XII
        35.150
        BEAM E4
        HS65 Cyclic
        Futaba S3154 Tail
        Scorpion 2221-8
        JETI Spin 44A
        JR RS 77
        Logictech 2100 TL Gyro
        Thunder Power TP2070-3SX
        A Bottle Of Guts, Neat.
          mini Titan - Proposed Configuration v2.1
          Guys, how come such a big price diff? Because s3154 is digital?
          HS81 really good enough?
          $42.50 - Futaba S3154 Digital Servo (Tail)
          $28.80 - Hitec HS81 (Tail)
          Okay.. now updated to following:
          Proposed Configuration v3.2
          $315.00 - mini Titan E325 kit w/Motor & ESC (Unassembled)
          $405.70 - Hitec OPTIC Tx w/6 Electron Rx & HS65HBx4
          $210.00 - Logictech LTG-2100T (gyro) w/Futaba S3154 Digital Servo (Tail)
          $110.00 - Thunder Power 11.1V 2100mAh /15C
          $169.00 - Imax B5 Li-po balance charger
          $1209.70
          "Keep Fly'in Till They're Dry."
          Mini Titan E325 SE Version
          Full CNC Metal Rotor and Tail
          Futaba GY401/Futaba 9257
          Hitec Optic 6 Electron/HS65HB
          Maiden on 26 Aug 2007
            there is a mini T in market pl.. with motor and esc selling for 200 only.. that will save u some cost
            For sale
              $1209.70
              btw for 12$ more, the 3154 holds the tail much better than the hs81.. with more precision.. but dont run it at 6V.. at 4.8 it is already very fast
              For sale
                glenn if you are punching full to 3000rpm then maybe you might want to flatten out your throttle curve in idle up? are you using governor? that would help your tail hold well too. if your throttle curve vary too much (i.e. rpm vary from mid stick to full stick) then your tail will have a hard time keeping up
                  yea
                  Helis
                  Logo 500 3D
                    actually why i had such a standard in mind is that 3krpm is what most 3d hs recommendation is at, but in truth i had yet to measure my hs in various setup.
                    also, there is this issue with the 887 dying over 10 flights, well it hasnt, but i'm waiting for it to come to that, so i am feeling pretty sensitive to the lack of holding.
                    either way i am exploring a tail servo option too, and until i tested my new 500SH motor, then i will decide to flatten out or not.
                    waiting for my new batteries now~
                    JR PCM 9XII
                    35.150
                    BEAM E4
                    HS65 Cyclic
                    Futaba S3154 Tail
                    Scorpion 2221-8
                    JETI Spin 44A
                    JR RS 77
                      hi glenn, just out of curiosity, why 500sh? its got a lower spec then the 500th with the same price..
