Lets see what heli we fly
    Heli Name : Hurricane 550
    Specs : HS635HB x3 + GY401 with 9254 + Guai 50a ESC + Guai 800kv motor + Guai BEC/DN 2s 1050mah + Electron 6 + DN 3s 2150 x2 + PQ 3s 2500XP x2.
    Modification :none!
    Pictures: only pic on this laptop.
      Heli: Mikado Logo 10 3D
      Cyclics: Futaba 9650
      Tail: Futaba 9254
      Gyro: CSM 720
      Motor: Hacker C50 13L Motor
      ESC: Hacker Master 48-3P opto ESC
      Power: Hyperion 5s
      TX: MPX Evo 12
      RX: ACT 8CH
      Mods: None
      f
        sorry forgot pic
        f
          EDIT/Update:
          Heli Name : TRex 450XL v2 Frame for Testing purpose
          Specs : Align 1400kv Outrunner, Hobby Wing 25A, Quark 3A BEC
          Modification : 2 Main Rotor Blades (395mm) flybarless, eCCPM 90 Degree with 3Servos. Elevated tail.
          Pictures:
          { Sorry for the blur images. My hand shake when taking it. The Align Pro blades on top is 335mm and it is put up there for size comparison }
            Opps forget to post mine, it is honey bee king with the skids from my king II kit
            I'm back!!!!
              My neighbour's heli
              Heli Name : TREX 450 SE V2
              Specs : Align 3550kv Motor, Pentium 30A ESC, Receiver Futaba R149DP, Futaba GY401 Gyro, Hitec 65MG servo x 3, Futaba 3001 tail servo, Futaba 9CHP transmitter, Xtreme Power 11.1v 2200mah 15c Lipo Battery
              Modification : Trex XL main rotor and tail rotor, Belt CP paddle & weight, DIY tail boom, aftermarket rubber belt, landing skid fitted with elbows for firmer foothold, reconstruct tail housing to fit SE
              Pictures:
                Originally posted by yeoman
                My neighbour's heli
                Pictures:
                thats not a SE v2!!
                For sale
                  more more more
                  I'm back!!!!
                    Originally posted by johndyl
                    thats not a SE v2!!
                    looks like XL with some SE components. the gears and part of the main rotor are SE, along with the body and the blue anodized bevels.
                      ya it is an upgraded xl not a SE v2.., in fact i think it doesnt even have a single SEv2 part
                      the metal parts for a sev2 are of a darker blue
                      For sale
                        As stated in the heli modifications, the metal parts are replaced with XL plastic parts. The reason is to avoid damage to the precious metal parts as the owner is still at beginner level. We do know that newer V2 metal parts are of darker colour. The main difference that differ SE V2 from SE is the tail metal housing's design.
                        Most senior Trex XL flyers would rather spend the money on the metal rotor upgrade rather than the body upgrade because body upgrade does little to improve the flight performance eventhough it is cheaper compared to metal CNC rotor upgrade. Attached is the CNC parts which was taken out from the heli and preserve in bubble wrap by the owner. Thanks.
                          Anyway, I have made a mistake in the battery spec. It should be 18c instead of 15c. So sorry for that. The Trex also has extra Align 4050kv motor and Align 35A ESC. Hee hee...
                            then why did u list it as a SEv2?
                            The SEv2 has more upgrades than that that improve flight characteristics, u can do a read on overseas forums. I can name at least one other upgrade other than the tail slider. And thats the upper head assembly(rotor hub, grips, thicker feathering) make for a much stiffer head and better flight characteristics.
                            changing the xl frame to any frame with direct servo to swash linkage(not only the SE or SEv2 frame) will reduce slop and improve flight charactertics, but that's only after going beyond hovering
                            For sale
                              I think you can check with RC Expert why they list the Trex as SEV2. The heli is bought from their website. Thanks
                                Hmmm... then what about my EP Spyhawk? How do I list it as? Half EP Spyhawk and half Honey Bee FP? Sorry me abit off topic
