TREX Head Dampener Upgrade - Red Dampers by Trueblood
    Any bros here tried using these and know where to get??
    Quote:
    Finally go inverted without weeble wobble!!! This upgrade replaces the stock o-rings...pack of four (set of two complete sets). The advantages of these dampeners is simple. They are able to produce a more responsive and tighter head dampening response by filling the entire dampening area of the head block with material. The dampeners are designed specifically for the T-Rex 450XL/SE head block and spindle, giving a tight dampening solution without needing to over-compress the rubber with spacers. Also, because of their shape and material, the Pro T-Rex Head Dampeners are able to last much longer.
    Unquote.
    they are super ex, compare to the original align ones..
    there are some kawada o-rings at rotor ... very good very tight fitting and "hard"
    Helis
    Logo 500 3D
      read that some ppl use fuel tubing...
      btw i am using OEM high hardness Orings.. they make the head quite stiff.. ala mini T. however, i am not doing any inverted flying, so q hard to comment..
      For sale
        byran rmb i told u about these like a few month's back, cos my o rings always wear out so fast.... ready heli doesnt ship to singapore i emailed them before
          thanks. did a search and could only find this but is currently out of stock. gees..they have the tools to install o-rings as well..
          http://shop.rotor.com.sg/show-detail.asp?prodid={4580A62D-BD6C-4B10-A633-44B3E2A93DBA}
          is this the one?
            my memory fails me again..yes i remember now..no wonder it sounds familiar.
            well they are currently out of stock now so hoping some shops will carry them..just like the levelling tool.
              well..any good tough o-rings is worth a try. where do u get them and how much do they cost?
                Hey.. i am also looking into getting good O ring too for my trex. The o ring seems to worn out fast on metal head than plastic kind as what i previously experience. Where to get good o ring stiff damper?
                Trex600 Nitro
                OS50 Hyper
                B6T 2In1 Regulator
                Zimmerman
                Rev Max
                DX7-AR7000
                GY401+9254
                S9351
                  Guys,
                  What about here?
                  Wild 3D dampers for Trex.....
                  Chai
                  Lets' moveon.......
                    Originally posted by moveon
                    Guys,
                    What about here?
                    thanks chai..but i am having some problems viewing that page for dampeners..
                      i ignore the security certificate thingy..can see now..
                      in fact..almost got blinded by the price..
                      $16.99!!! but they din say how many pcs do they come in..
                        More ex right? how good can it be ? I am looking for better damper too...keep me inform you find or place order ...but not too ex hor.....
                        Chai
                        Lets' moveon.......
                          rh1101 high hardness o-ring for trex S$4.90
                          u can get it from rce.com or call 96786552
                            yup thats the one
                            For sale
                              is this the one?
                              haha not too sure .. go by rotor and ask for 0-rings compatible for t-rex 450 ... (uncle mike if im not wrong) he passed me the kawada ones .. lasted quite long ... till now not much wear and tear .. about 1.5 mths now
                              Helis
                              Logo 500 3D
