HB FP Stock Main Gear (how many teeth?)
    Can anyone tell me how many teeth does the HB FP stock main gear have? I can't find any info on this.
    I need this info to do some homework like what pinion etc to get with my motor to bring the headspeed to 2200rpm.
    In politics, there are no permanent friends or enemies only permanent interest - Lord Palmerston
    it is 140T, coz same gear as my belt fp. my belt fp is 140T.
    Helis:
    Heli 1: Trex 450SE V1
    Status: Fit
    Date of Operation: 27 JULY 08
    Radio: Optic 6 + Electron6
    Batt: Zippy-H 3s 2200mah 20C
      With 140t, 10 pinion, 3550KV motor and assuming 85% efficiency, head speed is arnd 1500. Still beary beary low.
      Detach8 is right, mus change to 4100kv motor and 12t to get 2200rpm headspeed.
        using 2 cells:
        With 140t, 10 pinion, 3550KV motor and assuming 85% efficiency:
        head speed = ~1600
        With 120t, 10 pinion, 3550KV motor and assuming 85% efficiency:
        head speed = ~1860
        With 140t, 11 pinion, 3550KV motor and assuming 85% efficiency:
        head speed = ~1750
        With 120t, 11 pinion, 3550KV motor and assuming 85% efficiency:
        head speed = ~2050
        using 3 cells:
        head speed = ~2400
        head speed = ~2600
        i thought gws motor pinion is 11T?
        Helis:
        Status: Fit
          Aiyo, i running your motor leh...u so fast forget liao meh??
            i forgot liao leh. nv really go count before. not 11 meh. i alway thought it was 11T.
            Helis:
            Status: Fit
              Luckysoul,
              Not your fault for being so forgetful. It's the side effect of heli poisoning as what some bros here olways says...poison
                Luckysoul,
                lol. i tink i been seeing too many 11T heli. my belt fp is 11T, trex was 11T. den been fixing these two helis. so machiam tinking all heli is 11T.
                cham liao. this posion is damn deep!
                burning a BIG hole in my wallet. ARGH! my hp bill is $302.16!! been spending all money on heli den not paying my bills sia.
                Helis:
                Status: Fit
                  flameangel
                  stock blades can hover at around 1400-1500 headspeed. i've posted about this before.
                  the upper end of a 4100kv motor with trimmed blade (tested) is around 1700-1800rpm only, because of efficiency and drag. you won't hit 2000rpm unless you go 3s and get a high torque motor.
                  3550kv motor on a FP definately can fly. otherwise something must have been set up wrong
                    woops.. please use 12T if you have... the GWS 12T the plane gearbox is suitable for this purpose.
                      Detach8, really thanks for your feedback again.
                      Well, i can still fly, hover, alieron turns without any issues. My only problem now is the slow rudder turn despite shortening boom; the large turning angle during turning. Full rudder turn, the heli will spin slowly and drift away. You know what i mean. Will try to replace the fiber glass tail fin (6g) with plastic one to see if it helps. Not sure if a reduction in 3 to 4g helps?
                        hmm that i am not sure because ever since i went brushless, i converted my fp to a cp2 and used a HL gyro
                        slow rudder turns -> are you using the gws DD tail? try lowering gyro gain? ;)
                        shortening boom... how would this help rudder turns? the shorter the boom, the more force the tail needs to counter the torque. it's like a lever system. shorten boom may only help with tail-heavy CG problem.
                        did you trim your main blades? the stock untrimmed blades creates quite a bit of drag. you might want to try the wooden blades (which has an airfoil and better lift to drag ratio) or at least trim your plastic blades a little.
                          Detach8,
                          Well, i lowered the gain and lengthen the boom. Heli is perfect now. Spin fast.
                          Thanks
                            Wow great heli can crash and rebuild. what is it now , a fp or cp one.
                            when better will ff to see. Now upgrading 4 to 6 channel but got stuck .
                            happy flying.
                              MayMay,
                              I'm still on 4 channel except that my heli body is now fiber glass. http://www.heli-fever.com/product_in...424qcae7o3nuf1
                              You upgrading to 6 channel CCPM? You might well get the CP2 kit from JetHobby.
                              Going Separate
                              HB CP2 KIT (From JetHobby)
