Swash Type for beginner setting Should set to normal at independent aileron, elevator and pitch servo??? Or set to 120'. Belt CP is using what ?? I am a beginner trying to set up my Belt CP.
Help!!!!!!
Hi hope this helps
Hi ,
remember to rest the optic 6 before any configuration if you bought/was given a used optic 6, sometimes there are some settings stored from previous models.
i use hitec optic 6 too and the belt cp uses 120 swash type, the 120 swash type is orientated for the elevator servo BEHIND(by default optic 6),
but the belt cp elevator servo is INFRONT... you have to try play around with the reversing of servos and the ccmp ratio 70% or -70% !!!!but do not set them at 0 or it dosent work!!! also if you are using other servos such as JR servos you need to set the correct phase shift for the servo type( im not sure about the e-sky servo) either positive or negative phase shift..
if your settings ( with reverse and +70/-70 ) is correct.
- when you increase your collective, all the 3 servos should raise the swash plate up.
- when you push forward on your elevator stick, the rear 2 servos should raise the swash plate, while the front servo(elevator servo) is lowered causing the swash plate to tilt forward.
- when you push your roll/aileron stick left and right only the rear 2 servos should tilt in the direction of your aileron stick input.there should be veryverylittle or no movement at all on the front elevator servo.
**** for safety resons remember to unplug in you motor!!!***
alternatively you could bring your heli to some fun flys and the fliers can help you out! goodluck and have fun flying!Im a lousy flier. ☠
Thanks Bro will try it out...sigpicGround is closer than it appear...
bro best is to meet up with people who have experiene with setup unless you know exactly what you're doing. one wrong setup and your beltcp could injure you very badly. don't take it for granted!
i have made some short vids in the beltcp setup thread on the very basics of servo centering and swash movement. you should take a look at them to get a better idea of what you should be doing during your setup.
of course there will be many other factors you'll overlook. i was just helping somebody yesterday morning and the futaba channel 3 is actually inverted so we have to reverse channel 3. his beltcp made three scars on his hand...
you can join luckysoul at the bpp funflies. i'll be there as well!
