How pinion vs amp draw on Trex??
    anybody can explain what's the relation between pinion gear and amp drawon Trex heli??
    Like say, with same battery+esc+bl motor, how's the difference pinion gear change the amp draw?? low pinion=low or hi amp draw?? hi pinon=low or hi amp draw??
    This is my opinion:
    example on a regular Trex with a 450th (2950KV) and 2200mah lipos
    11T pinion = Low amp draw(around 16A)/long flight time (12-15min mins)/ Lower Headspeed (2000-2200rpm)
    13T pinion = Medium amp draw(around 24A)/average flight time(8mins)/ reasonable headspeed (2400-2600rpm)
    15T pinion = High amp draw(around 35A)/ short flight duration(5-6mins)/High headspeed (2800-3000+ rpm)
    In short, the more teeth on your pinion, the higher the load on the motor and subsequently the higher the amp draw on the batteries.
      i c .....
      so, higher pinion teeth=higher amp draw.
      10s!
        Yup, Higher number of tooth on the pinion, higher Amp draw as well as higher Headspeeds and Temperature
          If you want some serious effeciency I used to fly using a jgf 400dh on 8t pinion using 315 woodies for flight times around the 14minute mark. For duration flying (hovering and easy cruising) I would try a 9t with 325's to begin with and then experiment from there.
