!!Some Blade CX1 and Vortex Parts Are Not Compatible!!
    This is to inform those with blade CX that both parts are not compatible.
    I bought a blade CX from ebay about a month ago and went to sky to buy some spare parts for the heli and found out some parts will not fit.
    1. Inner shaft. The blades of the CX will not fit onto the vortex inner shaft.
    2. Vortex's inner and outer shafts are slightly longer compared to CX. So, you can't mix them.
    3. The fly bar will not fit. This is because the tracking adjustment will not fit onto the CX. The holes are of different size. You can replace it with the CX though. If you are using the fly bar with carbon shaft. Take extra care because the shaft is quite fragile.
    CX frame is also smaller. if you wanner use votex blades on the CX, you have to get the votrex blade grips oso.. etc
    Guys.. I can't do 3D. So if you see me flying inverted, I'm in trouble...
