micro heli for buzzing around?
    anyone got ideas for a micro for buzzing around the house and sharpening my hovering skills.It need not be collective pitch cos i dont intend to fly inverted with it however i hope that its tail is not powered by a tail motor but instead shaft or belt drive.I think the only heli that falls into this category is th dragonfly 22D from champion or the hornet v1 FP from HS .any other suggestions??
    Don't PCW
    Beam E4
    Trex 700 LE | YS91SR3C
    For FPs, non-belt drive and non shaft drive better.
    Cos when u drop the throttle stick to land, a motor tail will still hold sufficient rpm./
      Get Cupid from Rotor.
      2.4G
        why?
        Cos when u drop the throttle stick to land, a motor tail will still hold sufficient rpm./[QUOTE]
        may I know why?i thought that as rotor rpm decreases ,less tail rotor rpm will be needed to counter the torque.Or is this only particular for micro helis???
        Don't PCW
        Beam E4
