Originally posted by balance_mind
Walkera heli flyers ! Help!
$280 is the barebone kit for #60B?
No parts for #37? Especially main gear and main shaft.
Originally posted by WALKERASGD 280. may be can be lower if more._____________________________________________
Originally posted by be89zhi ghostfit
i will try my best to go down again this friday, may have to work lateahhh lama V3!! u trust my flying skill ah?
(Cheap to repair crash damage, so no stress !)
But my lama TX is mode 1 leh ?Seriously running out of ...Storage space !
Ghostfit da ge
dont mind i call u da ge hoh?mean big brother, ya after Eric trim the heli last fri, i was able to fly my heli last nite thanks to him but ho hover difficult still, but when the heli flew above my body height i landed her back lah bec of the walls around, i think this heli not safe to play in vold deck for newbies, n now i m kind of used to mode 2 liao so how huh?
Originally posted by GhostfitNo problems lah ! ...In my opinion, Lama V3 (In no wind condition) is the most stable RC heli to learn on !(Cheap to repair crash damage, so no stress !)
But my lama TX is mode 1 leh ?Love the sky with my babies
Walkera #60>>>1/8 T-trex
Vortex
Originally posted by WALKERAu mean with stock motor&batt, servos, gyro would be SGD 369.
what does it comes with ?
stock motor is it brushless or brush motor.
if the kits with brushless motor, servos ,gyro n esc ,what is the price like ?JR9XII PCM 72.xxx n XPS n FRSKY 2.4GHz
me is " Kancheong spider "
Originally posted by mh3400Is it possible for you to list down the specification on the 60#B ?
...just so long you dun call me "Uncle" or "Ah pek" can aredi !
Last nite I open up the Lama TX to convert it to Mode 2 ....Wah must solder the connection one !.....sigh ! ....the things I do for my mei mei !
hahaha no lah da ge lah handsome still, ai yo then i better make it, i will rush over for the meet, hahaha i can see alot of people interested in this heli, good more people more spare parts will b brough in i hope, then i dont have to headache liao,
Originally posted by GhostfitWah ! ....10 more customer like you and WALKERA seow leow !
Can ! Can !...just so long you dun call me "Uncle" or "Ah pek" can aredi !
Vortex
Pitch-axis
Roll-axis
Collective Pitch
Motor Speed
Others: Gear switch, 3D conversion, PIT adjustment, and exponential function
Specification
(1). Main Rotor Diameter: 620 mm
(2). Tail Rotor Diameter: 145 mm
(3). Overall Length: 600 mm
(4). Receiver: RX- PCM-701
(5). Drive System: 380 PH
(6). Battery: Ni-MH 12V 650mAh
(7). All-up Weight: 570~620g (Battery included)
(8). Transmitter: WK-PCM-0701
(9). Gyro: WK-G007
(10).Speed Controller: WTS-20A-02 Servo: weight 8.5g / speed 0.11sec/60°/ torque 0.9kg/cm / dimension 22.5X11.5X24mm
Features
1). CCPM mixing control system and collective pitch structure make perfect 3D maneuvers such as roll, inverted, and swoop flights.
2). The design of metal main frame, metal swash plate and metal rotor head is of legerity, innovation, precise and stability (except 59# and 60#). The autorotation landing system, made of high quality one-way bearing, maximally protects your helicopter from damage .
3). Highly efficient bevel wheel design is used in mesh between main gear and motor gear (except 59# and 60#).
4). 59# series' tail blades driven by axis provide easy adjustment, stable flight, and prompt reaction.
5). 60# series' tail blades driven by belt provide easy adjustment, stable flight, and low noise.
6). 380 carbon brush motor, matched with 20A brushed speed controller, provides more power to your helicopter.
7). 7-ch transmitter PCM701 with adjustable PIT parameter, throttle curve, and servo exponential function.
Add SGD90.00 for WK-WS-20-002 and 20A ESC.
Originally posted by be89zhahaha no lah da ge lah handsome still, ai yo then i better make it, i will rush over for the meet, hahaha i can see alot of people interested in this heli, good more people more spare parts will b brough in i hope, then i dont have to headache liao,....in fact, after seeing your baby last fri nite, I was even more interested in getting one ....but I really like the 68#B model leh ! ...looks like a bird of prey with it's bird like landing gear !
...How ? WALKERA ? any possibility of bringing in a few 68#B complete kits to Singapore ?Seriously running out of ...Storage space !
Originally posted by GhostfitI think WALKERA would be bringing in parts for your baby ....no more headaches....in fact, after seeing your baby last fri nite, I was even more interested in getting one ....but I really like the 68#B model leh ! ...looks like a bird of prey with it's bird like landing gear !
I don't think they are compatible. So no #37 parts loh.
Originally posted by WALKERAYup. 36 shaft and gear can use?_____________________________________________
Haven't seen a walkera heli in action before, anyone flying this heli?
If it uses 12V 650mah battery, how long can it last? The heli looks more heavy than HB. Nobody bringing in the Esky Belt CP?
AIR
HB K2 - Service
CopterX 450 - Hanger
IFO - Service
Walkera H05 mini plane
JR X3810
LAND
Kyosho Javelin - Garage
Tamiya TT01 Subaru WRX - In Service
Tamiya M03 Hello Kitty Swift - For wife
Cen Mini Madness - For son
Team Losi Speed T - In Service
Tamiya TamTech Frog
Sanwa MXA
Sanwa MX3S
Losi 2.4GHz
Crash Lander
Can crash land anytime anywhere
