Which GYRO to use? -Trex 450XL
    Intending to get for myself a TREX 450XL CCPM soon
    Need some help in choosing the gyros and servos to use..
    Any recommendations?
    Thanks!
    Futaba GY240 or Gy401 w/ HS-81
      gy401 and a futaba S9650
      Don't PCW
      Beam E4
      Trex 700 LE | YS91SR3C
        Go for GY401
        When I bought my first heli (Trex SE) 3 months ago, I chose GY240 ($185) over GY401 ($250) because I had already burst my plan budget. I found out later that the GY240 does not allow a high yaw rate control and GY401 does not have this problem (through forum discussions). I strongly suggest putting in the extra $65 to get the GY401.
        Swashhead
          also gy240 doesnt allow u to change the gain remotely, gy401 does
          Heli:
          Plane:
          . Ok Model Medallion
          . E*Star Storch
          . ElectriFly S.E.5a
          . Mpx EzGlider (Slope)
          Tx: JR 9XII
          Photo toy
          . Canon 7D & 500D
          . Canon 430EX & 580EX2
          . Canon 24-70 f2.8L
          . Canon 85mm f1.8
          . Tamron 10-22 ultrawide
            GY401 with HDS-877 Digital servo or HS81. More $$ then go for S9650.
            I am no Expert in 3D nor Sports flying. If you need advices on crashing, I am an Expert!
            Active :T-rex450SE like, 450TH 11T & CC35, R146ip, HS65MG*3, GY401 & HS81MG, mH ProFrame & blings, TP3S2100prolite & 7CHP 72MHz mode 2, EOS 7i & LBA6. MiniZ.
            Mike
              sorry for being newbie
              HS-81 for the tail rotor?
                just another servo to control the pitch on the tail blade
                Heli:
                Plane:
                . E*Star Storch
                . ElectriFly S.E.5a
                Tx: JR 9XII
                Photo toy
                . Canon 7D & 500D
                . Canon 24-70 f2.8L
                . Canon 85mm f1.8
                  ok thanks
                  so what servos do i get for the body? need 3
                    ok thanks
                    Commonly used are HS55, HS56 or HS65.
                    Mike
                      for the 3 servo's that control ur swash and pitch get the HS-65 HB's ... it's easier to center and stronger than the HS 55's
                        U need extra channel for the use of GY401
                        Mike
                          401, more x then 240, but will out last your models in the long run.
                          XRB SR Lama
                          Robotis Bioloid
                          Robot Bear
                            If you can put in the slightly extra money for a much better gyro, which allows you to enjoy higher performance, greater control, increased authority, please get the GY401. It will allow you to achieve much more in future and will serve you a longer time as your skills progress along.
                              401 401 GY401 401 401
                              If budget tight, look for a used one.....sometime can even get NIB and met up with nice people...
                              Heli
                              Plane
                              PT-17w : Sold
                              Buggy
                              Charger : Tahmazo T15
                              Balancer : TP205
