Hacker A20-6XL
    Hacker A20-6XL
    Hi
    Anyone running this motor?
    This seems the be the hottest motor currently for 3S setup.
    I might be ordering this together with the 17 T pinion. Anyone interested to order this combo in together to save on shipping?
    Anyone knows if anywhere in spore selling?
      hey am also interested in this Motor, it looks to be a good motor... would like to try it out as well...
      sar.ratha@me.com
      DEVIL
        Went down to SHS today to pick up some fibreglass cloth. Asked about the motor and they said they would get it in together with next order.
          i got some reviews abt this motor. i heard it runs quite hot.
          the Medusa motors seems to have an advantage and draws low amps.
          sar.ratha@me.com
          DEVIL
            trex i suppose. Goto www.trextuning.com and check the super 3S test.
              to add on, there is a video of this motor with TP 2100 3S in tppacks.com, showing insane power for its class. But do a search in RR, and u will know some problems such as HEAT.
                Hacker A20-6XL
                JetHobby is selling A20-22L , may be can ask him to order for you .
                  Slightly off topic. I'm using the max motor 450TH and recently found out that max amp is rated at 16.5 (JGF even lower at 15 amp). However, when i measure the amp draw at full throttle/pitch, its definitely above 20 amps. With normal flying and some aerobatics, i would guess that the amp draw on avaerage will be above the rated 16.5 amps.
                  If thats the case then continued use will deteriorate the motor. Then how come the 450Th has such good reviews other than the weight? BTW, i think my motor is dying but havent confirmed.
                    i believe this is the case also, cuz am having similar problem. i find that while doing more advance manouvers the motor bogs down. I need something better
                    sar.ratha@me.com
                    DEVIL
                      If only b-p-p has them both, the medusa 3400 and the A206xl, that would be great! Modefos has the medusa, and i think rchover has the hacker.
